It is currently Sat Jul 05, 2025 10:53 am
PostPosted: Thu Mar 02, 2006 11:27 am
Hello, I have a 1976 MR175 that has a shot ignition system. I was trying to decide if I should buy a whole new ignition system when I found a 1979 CR125R in a dumpster at work. I brought that bike home and a great idea came to mind, replace the Points system in the MR175 with the CDI Ignition in the CR. The ignition system in the CR was very clean, and I know it can work with a little modification. The parts bolt in because I have bolted them in, but im just wondering if anyone has done this before? Any help would be appreciated, Thanks.
P.S. This is a great website, keep up the good work :)
PostPosted: Thu Mar 02, 2006 9:52 pm
I dont have an answer to your cdi question, but I know of a place that can rewind your old stator if that will help. If you need it let me know. Gary
PostPosted: Fri Mar 03, 2006 12:17 am
This may work out alright.
I would suggest you make an accurate check on ignition timing once its running.......especially fully advanced at high RPM.
'84 Honda CR500
'84 CR125
'85 KX125
'83 IT490
'82 Maico 490
'80 YZ465
'75 Husky CR360 GP Mikkola
'75 CR250
'72 DT2MX
'91 XR200
