CDI Ignition from a 1979 CR125R in a 1976 MR175
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=929
Author:  burkemotorcross [ Thu Mar 02, 2006 11:27 am ]
Post subject:  CDI Ignition from a 1979 CR125R in a 1976 MR175
Hello, I have a 1976 MR175 that has a shot ignition system. I was trying to decide if I should buy a whole new ignition system when I found a 1979 CR125R in a dumpster at work. I brought that bike home and a great idea came to mind, replace the Points system in the MR175 with the CDI Ignition in the CR. The ignition system in the CR was very clean, and I know it can work with a little modification. The parts bolt in because I have bolted them in, but im just wondering if anyone has done this before? Any help would be appreciated, Thanks.
P.S. This is a great website, keep up the good work :)
Author:  Gary Starr [ Thu Mar 02, 2006 9:52 pm ]
I dont have an answer to your cdi question, but I know of a place that can rewind your old stator if that will help. If you need it let me know. Gary
Author:  expat [ Fri Mar 03, 2006 12:17 am ]
This may work out alright.
I would suggest you make an accurate check on ignition timing once its running.......especially fully advanced at high RPM.
