should a piston have slight rotational movement on the rod?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=935
Author:  cr60125r1 [ Sun Mar 05, 2006 12:50 pm ]
Post subject:  should a piston have slight rotational movement on the rod?
with my top end assembled with everything on except the head,i have slight rotational movement with the piston.no front to back or side to side just the slight rotational movement.it has a new wrist pin bearing and wirst pin also.the bike is a cr125.also befor assembly i checked the rod and it had no up and down play either.
