It is currently Sat Jul 05, 2025 7:26 am
PostPosted: Fri Mar 24, 2006 8:46 pm
Hello everyone! Will a 1979 CR125R motor work in a 1980 frame? I know the cylinders are a bit different, but if I use an entire motor, will it work?
Thanks!
PostPosted: Fri Mar 24, 2006 9:40 pm
You cannot swap the entire motor from a 79 to a 1980. The 79 had the exhaust port exiting at an angle. The 1980 exhaust came straight out. The frames were different. Maybe the bottom ends will swap.
PostPosted: Sat Mar 25, 2006 6:32 am
Thanks! You just saved me some cash!
Users browsing this forum: Google [Bot] and 39 guests
