1979 CR125R Motor in a 1980 CR Frame
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=957
Author:  Thor [ Fri Mar 24, 2006 8:46 pm ]
Post subject:  1979 CR125R Motor in a 1980 CR Frame
Hello everyone! Will a 1979 CR125R motor work in a 1980 frame? I know the cylinders are a bit different, but if I use an entire motor, will it work?
Thanks!
Author:  Elsinorestuff [ Fri Mar 24, 2006 9:40 pm ]
You cannot swap the entire motor from a 79 to a 1980. The 79 had the exhaust port exiting at an angle. The 1980 exhaust came straight out. The frames were different. Maybe the bottom ends will swap.
Author:  Thor [ Sat Mar 25, 2006 6:32 am ]
Thanks! You just saved me some cash!
