Checking ignition coil and stator on a 75 cr-250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=960
Author:  evelmike [ Tue Mar 28, 2006 7:12 pm ]
Post subject:  Checking ignition coil and stator on a 75 cr-250
Does anyone know what kind of ohm reading a good coil will have? How do you check the stator? How many volts should it produce? I think my ignition is breaking down at high rpm. Any ideas?
Author:  ricortes [ Wed Mar 29, 2006 12:41 pm ]
For the primary ~2-3 Ohms would be about right. Never checked secondary but probably 10X that.
Intermitant failure on coils does happen but it is less common then a dead coil or [plug, points, capacitor, timing, carburetion] type misses.
