Removing 1976 CR125 Wheel Bearings
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=999
Author:  Ruairi [ Mon Apr 17, 2006 10:32 am ]
Post subject:  Removing 1976 CR125 Wheel Bearings
Sounds easy when you read the manual??
Trying to change the front hub bearings and getting nowhere fast.
I simply cannot get enough purchase on the bearing edge to knock the old bearings out. I am hoping that if I can get the first one out then the spacer can be removed and the second bearing will be dead easy
I am using a thin punch and a hammer.
What tips have you guys got please??
Author:  Elsinorestuff [ Mon Apr 17, 2006 7:17 pm ]
Make sure you push the center spacer tube to one side as much as you can so you can get to the bearing. I use an old 3/8 extension about 10 inches long to pound on the bearing. Try hitting it at different angles too.
Author:  redrocket190 [ Mon Apr 17, 2006 10:17 pm ]
Try warming the hub too. It will expand faster than the bearing and make it a little looser...
