It is currently Tue Jun 17, 2025 3:48 pm
 Post subject: 1993 YZ125 No Spark
PostPosted: Sat Oct 11, 2014 7:16 am
Tried everything. Replaced coil. (Out of Spec) Has new pick up coil (Specs at 212 ohms) Replaced the large field coil. (Out of spec) Having done all that and getting nowhere. I figured it must be the CDI? Ordered a used one from a wrecker in the U.S. "from a running bike" Still nothing. I'm still leaning towards a bad CDI. Any insight or ideas of what to check next would be deeply appreciated!
 Post subject: Re: 1993 YZ125 No Spark
PostPosted: Mon Oct 20, 2014 6:23 am
Have you checked to make sure the ignition coil is grounded?
PostPosted: Sat Oct 25, 2014 8:57 am
Bolts to the frame. Cleaned and checked.
PostPosted: Mon Oct 27, 2014 9:51 am
Unplug the wire from the kill switch (button) it case the switch is bad.
PostPosted: Tue Nov 17, 2015 4:11 am
Did you get this issue resolved ???
PostPosted: Tue Jun 07, 2016 10:52 pm
This is the information that is appropriate to publish the full details.
จีคลับมือถือ
Users browsing this forum: No registered users and 6 guests
