It is currently Wed Jun 18, 2025 1:00 am
 Post subject: 'YZ465G bore wear.
PostPosted: Thu Oct 20, 2005 8:35 pm
Hi,
I am racing two '80 model YZ465G's and both are suffering severe bore wear at bottom of cylinder on intake side.
The wear mark corresponds to the cut out in the piston.
I was wondering if this was caused by a lack of skirt support due to the intake cut away.
Both pistons are Wisecos.........fuel oil mix is 32:1 Yama R
 Post subject: YZ465 bore wear
PostPosted: Fri Dec 09, 2005 10:28 am
The type of bore wear you describe is not uncommon in those big bore Yamahas. Most wear is caused by DIRT coming thru the air filter. The Yamalube at 32:1 should have provided enough lubrication to prevent piston contact with the cylinder except when they ping under load. Using 100oct. fuel mix helps there to reduce pinging.
Also, early Wiseco pistons were notorious for wearing out fast, and also creating bore wear in the process. Their new stuff is much better, but I still prefer to use oem or oem style if it's available in the size I need.
OriginalDirt
74 AMPI CZ125
73 CZ400
73 CZ250 Basket case.
72 SherpaT 350
75 Montesa King Scorpion
72 Rickman 125 Enduro
70 Honda CL70
72 Honda Z50
00 DRZ400E Baja'd
Users browsing this forum: Google [Bot] and 13 guests
