It is currently Tue Jun 17, 2025 7:56 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 27, 2014 3:52 pm
Well it popped off! It ran for about 30-40 seconds, then kept trying to start, then never got her to turn over again - kicked it til I was warn out. Gas is fresh and tank is clean, so I'll pull carb and see if that helps - - has good blue spark tho! THANKS for the wiring tips!!!
PostPosted: Thu Feb 27, 2014 4:40 pm
Single wire kill switches will ground out to the handlebars when the switch is activated, . . . or . . . some switches (like your toggle switch) will need a second wire attached that will go to a near-by ground . . . NOT back to the coil though.
PostPosted: Wed Mar 05, 2014 5:17 pm
on a 2 pole switch one wire goes to the black wire to your coil and the other needs to go to ground.
PostPosted: Wed Mar 05, 2014 5:18 pm
might need to clean the carb if it has sat a long time since it was last run.
