82 yz80 steering coolant leak https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=28&t=2738 |
Author: | heetseeker [ Mon Jul 05, 2010 11:55 am ] |
Post subject: | 82 yz80 steering coolant leak |
Finally found a place where I can ask this question.... I took on a project for a buddy who has been over seas fighting the taliban and i'm stuck and need your help if possible. I'm working on an 82 yz80 for his kid and it runs great except for the coolant leak coming from the steering stem area. I've been on bikebandit.com and all of the parts to fix this are nearly $70 plus shipping and i'm trying to keep this as cheap as possible. Has anyone done a bypass on the steering stem for this bike? I do need some bearings in the steering stem but i'm sure this will be a common problem. The issue is that there isn't any room to put in an elbow... Any advice would be appreciated... Thanks! |
Author: | mrmikkelsen [ Thu Jul 15, 2010 8:45 am ] |
Post subject: | Re: 82 yz80 steering coolant leak |
I had a 1982 yz250 that had the steering head coolant path bypassed. It had another spigot welded to the radiator and two long coolant hoses going down to the motor. I doubt that cost much less than $70 to do if you had to pay to have it welded. It was probably done only because the steering had pathway was corroded beyond useable. If you take your 80's steering assembly apart you'll be able to see if the sealing surfaces are too rusted to seal. If they are good, you will probably want to do it right. If they destroyed, then you have the bypass option. Good luck! Jon |
Author: | heetseeker [ Sun Jul 18, 2010 5:45 pm ] |
great advice, i'll tear into it this week and post my results. s |
