It is currently Fri Aug 08, 2025 5:31 am
 Post subject: 1976 YZ80 Carb.
PostPosted: Fri Oct 29, 2010 3:46 pm
Mini Bike Experts. There is something wrong with the carb. on my YZ80. It is probably worn out. For a few bucks I can get a new carb. but they all need a different manifold. It looks like the bolt pattern is the same. The 76 CARB. attaches with two bolts. The 77 has the typical rubber manifold that uses a radiator clamp. Is the bolt pattern on the cylinders the same?
8)
