It is currently Tue Jun 17, 2025 11:05 pm
 Post subject: 99 YZ125 tranny oil
PostPosted: Tue May 03, 2005 6:45 am
I need to change the tranny oil in my son's 99 YZ125. What oil do you recommend, and what is the proper amount?
I know this isn't considered "vintage", but this is the most informed forum I've seen.
PostPosted: Wed May 04, 2005 8:33 am
I use Maxima Tranny oil.
There's an oil level check bolt right in the side of your cases (On Hondas, it's a combination hex/phillips head bolt on the right side). Remove the bolt, then with the bike level, fill the tranny until oil starts to drip out of the bolt hole. Replace the bolt. Your done.
PostPosted: Sun May 08, 2005 4:27 pm
thanks for your help, I found the bolt. I need to pick up some tranny oil, and change the oil.
thanks again.
