It is currently Tue Jun 17, 2025 2:12 pm
 Post subject: Help with 1975 RM125
PostPosted: Fri Apr 13, 2018 9:42 pm
Hello,
I recently acquired a 1975 RM125 with a seized crankshaft. The frame is 19515, the engine is stamped "RM125-19682" on the left hand side of the crankcase.
Is the correct part number for the crankshaft assembly
12200-41001 or 12200-41610, for 1975 RM125M per CMSNL, or...
12200-41301 for 1975-1978 RM125 and 76-78 RM100 per OEM-CYCLE.com,
or some other number?
Also, are the parts 12200-41001 and 12200-41301 interchangeable?
Thank you for any help,
Ben
 Post subject: Re: Help with 1975 RM125
PostPosted: Sun Apr 15, 2018 6:16 am
I received the following reply from vintage Suzuki (thank you, Tony):
Part # = 12200-41001
Part Description = CRANKSHAFT ASSEMBLY
Model Count = 2
RM100A 1976 98 RM100 OFF ROAD
RM125-M 1975 123 RM125 OFF ROAD
Part # = 12200-41301
Model Count = 3
RM100B 1977 98 RM100 OFF ROAD
RM100C 1978 98 RM100 OFF ROAD
RM125A 1976 123 RM125 OFF ROAD
The second number is not the correct crank.
