will rs 175 cylinder work on pe 175 and gasket question? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=1472 |
Author: | Nathan [ Thu Jun 07, 2007 6:25 am ] | ||
Post subject: | Re: will rs 175 cylinder work on pe 175 and gasket question? | ||
As for the crankcase fix, I recommend "Marine Tex" to fix it. It is super strong, will withstand hammer blows, won't breakdown from oil, gas, or water, and it's sandable and paintable. I've repaired holes in the bottoms of cranks with it, sanded and painted it, and you can't tell it was ever damaged. Best yet, it holds up after years of use. You can get it at most any marine store like Boaters World or West Marine.
Author: | mshade [ Wed May 28, 2008 1:49 pm ] |
What year is your PE? Only the top of the cylinder is the same part on RS and PE and only for the 1980-1984. The cylinder itself is different for the RS and PE. I believe the RS has a lower exhaust port, maybe the pipe could be modified but it seems like a lot of trouble. Check with Brenden at Bike Bone Yard (http://www.bikeboneyard.com/) for a real PE cylinder or wait till one comes up on ebay. 1980-1984 PE175 all use the same head though. Here's my 1982 RS175: http://www.bikepics.com/members/mshade/82pe175/ |
