It is currently Wed Jun 18, 2025 1:59 am
PostPosted: Tue Jun 10, 2008 6:47 am
I think that I have lost a few teeth off the kick start shaft or perhaps the drive gear.
Does anyone know if I can replace either without opening the engine case?
If so any pointers would be great.
Gallows
'97 Suzuki TL1000
'89 Suzuki RM250
PostPosted: Fri Jul 18, 2008 6:54 am
You can replace the kick start gear assembly without splitting cases.
You will need to remove the right side cover and possibly the clutch assembly depending on how well your fingers work in tight spots.
I just replaced mine without removing the clutch pack.
Make sure you get the spring and what not "clocked" correctly, if not it can make a nasty mess when you start/try to start the bike.
Users browsing this forum: No registered users and 4 guests
