need help with a 76 rm125 please!
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=2718
Author:  76rm125 [ Fri Jun 25, 2010 10:43 am ]
Post subject:  need help with a 76 rm125 please!
i have a 76 rm 125. i just bought it and i guess its bored 40 over. but thats not the problem. i just cleaned the carb and it was pretty clean... sprayed the jets and after that it ran pretty good. idled good and ran good.
i just started it up and the little screw with the spring in it.. i think thats the idle screw right? i turned it just a half turn and now it ran a little funny.. now the bike won't start.. any help?
Author:  Axceler8r [ Tue Jun 29, 2010 1:05 pm ]
Post subject:  Re: need help with a 76 rm125 please!
The screw with the little spring on the carb could also be the Air Screw. Usually turning the idle screw will only cause it to idle at a higher RPM, not prevent it from starting. The Air screw, however, can cause it to run funny (and possibly not start) because the air-fuel mixture is out of whack. Turn the air screw inall the way until it stops (do not force it). Then turn it out 1-1/2 turns. This should be a good starting point. You did not mention your location, so you may need to go a 1/2 turn in or out to get the correct setting. Good Luck!
