It is currently Tue Jun 17, 2025 9:11 pm
 Post subject: 1985 rm 125 help
PostPosted: Sat Feb 01, 2014 8:02 pm
i need help i just bought a 85 rm 125 and brought it home checked it over and put antifreeze in it, shortly there after i had a puddle on the floor and found it was coming from a hole in the side case behind the water pump, if any one can help i would greatly appriciate it
 Post subject: Re: 1985 rm 125 help
PostPosted: Sat Feb 01, 2014 8:08 pm
as far as why theres a hole here and what should be in it and why anti freeze is coming out of it.
PostPosted: Sat Feb 01, 2014 10:57 pm
That hole is supposed to be there and nothing should be in it. That lets you know the water pump seal has failed and it needs to be replaced.
PostPosted: Sun Feb 02, 2014 9:01 am
thank you very much
