cleaned out carb on tm400 and added clean fuel, smoking!!!
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=4271
Author:  bdbaggr [ Wed Apr 09, 2014 9:08 pm ]
Post subject:  cleaned out carb on tm400 and added clean fuel, smoking!!!
i have a 73 tm400 that needed a carb cleaning and fuel change, has been really hard to start... so disasembled the mikuni and took apart, cleaned and re-assembled now the guy i bought it from had it mixed at 20:1 it ran decent but would die and terrible to start. after cleaning and mixing at 32:1 it started first kick... and just smoked! shut it down, didnt change the air/fuel or idle screws much kicked it again and bam, first kick started up... just kept smoking like it was rich. but was mixed leaner... any ideas?
Author:  tnr [ Thu Apr 10, 2014 9:35 am ]
Post subject:  Re: cleaned out carb on tm400 and added clean fuel, smoking!
You may need to run it awhile. At 20:1,that pipe has a lot of oily residue that may take time to burn out. If it keeps smoking it may have a bad right side crank seal.
Author:  volkrt [ Fri May 23, 2014 4:21 am ]
thats the first ever TM I have seen with a supertrapp exhaust...lol its pretty cool actually
