changing crank seals on 77 pe250
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=4431
Author:  quacked1up [ Sun Mar 01, 2015 9:45 am ]
Post subject:  changing crank seals on 77 pe250
Does anyone know if the crank seals can be changed without splitting the case?
Author:  tnr [ Tue Nov 17, 2015 11:52 am ]
Post subject:  Re: changing crank seals on 77 pe250
It looks like the right side seal is behind the bearing so you would have to split the cases. You can look at the diagram at Partzilla.com.
Author:  robthesnail [ Sat Dec 12, 2015 4:10 am ]
i am about to split my rm250..1976....im doing crank bearings, rod and new bored out .050 top end...
i have never split an engine but am gonna give it a go
Author:  Nevergivx [ Tue Jun 07, 2016 10:51 pm ]
You take the information from this place, why I could not find it.
