It is currently Wed Jun 18, 2025 4:29 am
PostPosted: Sun Aug 28, 2005 5:09 pm
I'm just getting started with Vintage Suzukis (TM100,125 & 250) and wonder what things need to be changed to make the bikes competitive. Also what aftermarket parts should I keep an eye out for? Thank you for any help you can offer!
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Mon Sep 26, 2005 10:18 am
The TM's were pretty competitive right out of the box. They could use better rear shocks and cartridge emulators in the forks ( if avail. for the fork size).
Better reeds ( Boyesens were the original hot set up), bored carb bodies, and milled heads also pumped up the power. If you can find a DG radial head, they worked great along with an aftermarket pipe.
OriginalDirt
74 AMPI CZ125
73 CZ400
73 CZ250 Basket case.
72 SherpaT 350
75 Montesa King Scorpion
72 Rickman 125 Enduro
70 Honda CL70
72 Honda Z50
00 DRZ400E Baja'd
PostPosted: Mon Sep 26, 2005 3:09 pm
Thanks O.D. ! :D
J
1988 Honda CR250RJ
1983 Honda CR480
1979 Honda CR250RZ
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
