Suzuki TM Tips and Tricks?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=29&t=759
Author:  J [ Sun Aug 28, 2005 5:09 pm ]
Post subject:  Suzuki TM Tips and Tricks?
I'm just getting started with Vintage Suzukis (TM100,125 & 250) and wonder what things need to be changed to make the bikes competitive. Also what aftermarket parts should I keep an eye out for? Thank you for any help you can offer!
J
Author:  original dirt [ Mon Sep 26, 2005 10:18 am ]
The TM's were pretty competitive right out of the box. They could use better rear shocks and cartridge emulators in the forks ( if avail. for the fork size).
Better reeds ( Boyesens were the original hot set up), bored carb bodies, and milled heads also pumped up the power. If you can find a DG radial head, they worked great along with an aftermarket pipe.
OriginalDirt
Author:  J [ Mon Sep 26, 2005 3:09 pm ]
Thanks O.D. ! :D
J
