It is currently Tue Jul 01, 2025 3:17 am
PostPosted: Fri Jan 06, 2006 12:48 am
Hi,
Can anyone tell me where to look for the engine and frame numbers on this bike?
Cannot seem to find any numbers....... :(
'84 Honda CR500
'84 CR125
'85 KX125
'83 IT490
'82 Maico 490
'80 YZ465
'75 Husky CR360 GP Mikkola
'75 CR250
'72 DT2MX
'91 XR200
PostPosted: Tue Apr 06, 2010 9:40 pm
Sitting on bike, look on the right hand side of steering head half way between steering head bearings upper and lower (this is part of frame behind front number plate). This will be your vin. The engine will have a metal tag signifying the engine number. This is usually found above the countershaft sprocket on engine center case. If the frame has been powder coated, the vin. will be hard to see. You may have to sand the frame steering head on right side before it will show up. I have a model of this same bike.
