It is currently Tue Jun 17, 2025 10:26 pm
PostPosted: Tue Mar 10, 2009 8:12 pm
frame # is in the pic, got this in a pile of parts. thanks .
PostPosted: Wed Mar 18, 2009 12:51 pm
Appears to be a 1969 Cross, probably a 360cc. You have to get the serial numbers off the engine to be sure.
BTW: I have a 1973 400 Cross.
PostPosted: Fri Mar 20, 2009 11:56 am
thanks, ill do some checking. Kicker is toast, Do they have a hi low lever somewhere, the actual motor itself seems tight.
PostPosted: Fri Mar 20, 2009 3:09 pm
My guess is the shaft that goes down on the left side just under the fins is the shift.
