It is currently Tue Jun 17, 2025 3:39 pm
PostPosted: Fri May 07, 2010 1:19 pm
Hi
can someone please assist me with this problem as i cant work it out from the wiring diagram.
It concerns the 2 wires which come from the magneto to the rectifier (1 pink and 1 green). the rectifier has a 2 prongs and the diagram confirms this is correct for the A7 model. so one wire needs to attach one on the rectifier prongs ( currently the pink) and the other prong must attach direct to the the battery for charging purposes.
which leave me with the green wire coming from the magneto? what does this attach to? currently it not attached to anything.
i have tested the battery to see if im charging it whilst running , buts its getting only slightly high volts than when not running, the manual states it should be around 8.5 from the rectifier pre conversion. but its only just around 6 v only a fraction higher than when the engine is off.
so i need to find out where this green wire attaches to and how it all links together so it charges the battery
can any please help
thanks
PostPosted: Sat May 08, 2010 4:25 am
anyone know about this wiring on this bike?
