It is currently Thu Aug 14, 2025 6:22 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: MR250 richness
PostPosted: Thu Aug 12, 2010 8:53 am
Ryan, you were right it was just flooded. The next morning I went out and started it up on the 2nd kick, and got some real nice RPM range (havent been able to do that for awhile_, but after maybe 5-6 seconds of revving, it will bog back down and putter with no throttle response, then about another 5-6 seconds I can rev it high again. When I'm revving it high, and I let out the clutch to go forward, it just starts the bogging down again. I think I'm going to check the crankcase for floodage today.
Thanks for your help
PostPosted: Fri Aug 13, 2010 6:26 am
Your welcome. And now it sounds like the ignition timing might be off have you timed it correctly? And also did you try a new spark plug?
-Ryan
PostPosted: Fri Apr 22, 2011 6:51 pm
Wow. It sure has been awhile, almost a year since I posted this. Well, I still have the ol' MR, and I was just reminded of it yesterday when I was fixing up a snowmobile with a friend. He had bought some new carbs for his Yamaha, and the old ones were Mikuni VM36's. I knew I had heard about this model somewhere, but couldn't put a name on it, then I remembered about you guys talking about taking off that old Keinhin and putting on the Mikuni.
Now, obviously I will have to put on all new jets, but besides that, this should work right? As long as the body itself is a VM36, it doesnt matter what it came off of right?
I went outside to the MR after this, rocked the bike back and forth for a minute or two, kicked it, and on the second kick it started up. Was able to rev through the ranges for about 3-4 seconds, then it started the all so familiar bogging down that plagued it before. I was still able to ride it down the road and back up my driveway though. Exicted to try and get it running. I will have to refresh myself on what I had learned before though, I have forgot alot about what I have diagnosed.
Also, gave it a compression test, and got 130-135. I must have mis-calculated it the one time I got 110.
PostPosted: Wed Apr 27, 2011 9:37 am
I would think any VM36 would work. But I only have two Mikuni carbs and am not an expert. Make sure you have a 2.5 slide in it. I like to run 40 pilot; 270 main; 6dh7 needle; 159q4 needle jet.
PostPosted: Thu Apr 28, 2011 10:43 am
Good luck in working the MT intake manifold up & around the 36mm carb intake. Be careful it doesn't split on you.
~JM~
WWW.CADDY500.COM
The High Performance
Big Block Cadillac Forum
Users browsing this forum: No registered users and 47 guests
