It is currently Wed Jun 18, 2025 7:38 am
 Post subject: 79 RM250 case splitting
PostPosted: Sat Nov 13, 2010 1:30 pm
I have a bottom end Im parting out, I need to split the cases. Wanting to know, do i use the splitter on the clutch side or the other? On the other (flywheel) side there are only 2 case holes for putting the puller screws into.
Or a scan of the case splitting part of the manual would be awesome.
thanks
02 crf450
00 kx250
84 cr250 (prj)
PostPosted: Mon Nov 29, 2010 3:27 pm
Are you sure you need to use a splitter at all? I split the cases on a 78 rm125 and just used a rubber mallet. The cases had a gasket in the middle and it came apart pretty easily.
PostPosted: Tue Nov 30, 2010 12:21 pm
I could do that i suppose, you just hit the crank?
02 crf450
00 kx250
84 cr250 (prj)
PostPosted: Mon Dec 06, 2010 1:50 pm
I have to agree with Dirtbikemikey. Take a rubber mallet and pop the cases a couple of times and it will separate.
Carebeful about hitting the end of the crank without some kind of buffer so you don't ruin the threads. This is what I did to my RM100 bottom end recently. Once it separated a little, I ran a razor blade around the cases to cut the center case gasket loose and pulled it apart. Good luck!
Kevin
