It is currently Thu Jun 19, 2025 8:50 pm
 Post subject: 79 cr250 bearing
PostPosted: Wed Dec 15, 2010 7:40 pm
anyone know how to remove the clutch lifter shaft bearing on 79 cr250 I need to remove for blasting and powder coat thanks, Craig
 Post subject: Re: 79 cr250 bearing
PostPosted: Thu Dec 16, 2010 10:01 am
i tig-weld an allenscrew whitch head fits into the bearing to it.
than heat the case and pull at the screw.
or your next motorcycle shop may help you, they have special tools for pulling sutch bearings.
PostPosted: Fri Dec 17, 2010 6:03 am
I guess I will bring it to my local shop to be pulled the bearing is NA is there another source to get one
PostPosted: Fri Dec 17, 2010 12:11 pm
it´s a standart bearing,
HK1612
id 16mm od 22mm h 12mm
the small seal is also std. 16x22x3mm
Users browsing this forum: Google [Bot] and 36 guests
