It is currently Fri Jun 20, 2025 12:16 am
PostPosted: Mon Nov 15, 2010 4:04 pm
I just put a 83 cr480 front end on my cr125. Can anyone tell me the proper air pressure and any tips on the oil/air pressure ratios to help in handling. I weigh 150 lbs with out gear.
Thanks in advance,
Tom
1980 honda cr125
1979 can am mx5 250
2005 Yamaha yz167
1980 Honda cr125r
1979 Can-am mx-5 250
2005 Yamaha yz167
Two Strokes Rule!
PostPosted: Tue Nov 16, 2010 10:37 pm
http://www.alp-sys.com/honda-elsinore/elsieref/viewtopic.php?f=2&t=217&start=0
This is a link to the setup for 1982 and 1983 CR480R forks. IMHO you are going to need stiffer fork springs, probably about 0.43 kg/mm v 0.34 kg/mm stock. Use the bleeders on the forks to neutralize air pressure as the forks warm up, not to pressurize them. Start with the stock oil height and add 10mm / 10ml increments if the forks bottom.
PostPosted: Thu Nov 25, 2010 8:35 am
Can anyone else help me with this?
Thanks,
Tom
1980 Honda cr125r
2005 Yamaha yz167
Two Strokes Rule!
PostPosted: Wed Dec 08, 2010 7:57 pm
After disasembling my forks i realize i have 1982 kyb not 1983 showa. I bought race tech emulators and am about to do the install. any tips?
Thanks in advance,
Tom
1980 Honda cr125r
2005 Yamaha yz167
Two Strokes Rule!
PostPosted: Sun Jan 09, 2011 5:50 pm
Well, I bought what I thought was a fork for a 1982 CR480 that turned out to be a 1983 and I need some guidance/help.
Can anybody help me figure out how to set the perforated ring that is INSIDE the BOTTOM of the TUBE. This ring has 4 holes on its periphery that can match one hole on the tube (see photo).
I am tempted to align one of the holes with the hole in the tube. Is that what it should be?
Also, that inside ring seems to castellated probably for a special tool. Is that right, where can I get this tool and how to use it?
I suppose that there must be tuning instructions somewhere right?
PostPosted: Sun Jan 09, 2011 5:52 pm
P
PostPosted: Sun Jan 09, 2011 5:53 pm
Cant figure how to attach a photo here, so here is a link to the photo:
http://picasaweb.google.com/ericf318/CJMugenXR500Project#5560012396167572082
PostPosted: Sun Jan 09, 2011 8:59 pm
eric318 please let us or me how you like them i looking for set right now for my 79 cr125 with 80 swing arm :)
PostPosted: Sun Jan 09, 2011 10:35 pm
Hi Badsix, it will still be a long time before I get this baby in the dirt I am afraid... so dont wait for me.
I mostly heard good things about the 83 fork, less so about the 82 and not good stuff about the 81. The 83 is the latest / most advanced of the pre-disc-brake era and given how cheap they go for, it is hard to beat.
One warning though: parts are VERY hard to find. It took me weeks of research to finally find a dealer who stocked and sold the bushes and guides (oil and dust seals are easy though). But impossible to get the simple back up rings (just big washers really), I had to get a pair of 97 CR125 rings and grind them to size.
Users browsing this forum: Bing [Bot] and 27 guests
