JM,
Your bike looks lean, mean, and ready to go! The MT gearbox should work great for street riding, and the MT front brake is actually pretty decent.
As you may know, I've been hopping up two MR175-powered bikes for what seems like forever. One thing I've learned is that the MT125, MR175, and MT250 cylinders are virtual clones, differing mainly in dimensions, not design.
Unless you've opened up that MT intake manifold to where the rubber is paper-thin (NOT recommended, obviously), you won't get any more than 29mm or so of poor-quality flow out of any >28mm carb. I fit a 30mm in my MR175 manifold (extremely similar to the MT250's manifold) and it worked like crap despite many jet / needle / slide changes. I couldn't believe how much better it ran when I put the stock 28mm carb (identical to the MT250's) and manifold back on. Fixing the 30mm setup took a lot of work which I won't bore you with, but it can be done.
Long story short: if you want max performance, minimum down time, and plenty of online support, I would go with the CR250 (or MR250?) cylinder transplant. Your carb-mounting problems will vanish, your existing pipe will match the porting, and your bike will fly (you may be surprised at how well the 32mm carb works, especially down low). If a bolt-on top-end solution like that was available for my MR, I would have done it in a hearbeat.
If you decide to stick with the MT250 cylinder there's still plenty that can be done, but it will take a lot of work to get to maybe 75-80% of the CR250's output.
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
