It is currently Mon Aug 11, 2025 10:03 am
PostPosted: Thu May 05, 2011 11:41 pm
Curious mainly about the flywheel / electrics... I'd like to "dual sport" my CR and make it street legal. In Idaho, that means a headlight and tail light. I've got a motor from an '81 ATC 250R along with the complete wiring harness. Will the flywheel / stator fit in the CR? Also just kind of curious, how similar are the rest of the engine- piston / top end, transmission internals? The cases are WAY different, the ATC has a counterbalance sticking way out the front...
PostPosted: Thu May 05, 2011 11:46 pm
Hey Dorkpunch havnt seen you on a board in ages.
PostPosted: Fri May 06, 2011 7:13 am
You just havent been to any of the right boards. :D
PostPosted: Fri May 06, 2011 4:53 pm
no.
and the cylinder and head are different in porting and style, so that the ATC has ~10hp less.
piston and rod are the same.
check the parts catalog here: http://www.hondapartshouse.com/honda-parts.aspx?aribrand=HOM
Users browsing this forum: Bing [Bot] and 11 guests
