It is currently Sat Jul 12, 2025 6:57 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Oct 24, 2011 3:21 pm
~JM~ wrote:
Your doing the CR top end swap? What carb are you planning to use?
I don't know if that pipe will fit properly or not with the CR top-end. I suppose it should & it should be much quieter than the DG down-pipe. I'm looking forward to hearing about your end result. I need to get back to work on mine.
~JM~
yep CR cylinder is bored, honed and im just waiting on the Wiseco small end bearing and i can fit it up. My next problem will be the intake but i may just modify the split OEM one that i have... Carb... well i did see a few CR guys were fitting a Mikuni VM36 round slide carb for around $100, that sounded like a good plan as ive no carb at present, the closest i have on my bench is a PWK28, does anyone think thats a goer? if so im almost ready to roll!
The pipe should fit the 73/74 top end just fine, ive mocked it up and the 73/74 is the same exit and spacing as the MT etc.
Quieter is good round here.... ;) :)
PostPosted: Mon Oct 24, 2011 3:23 pm
b-joe wrote:
cr topend + mt pipe.
you won´t get the power what a cr usually has.
You are right, but i will have more power than the MT and yet retain its look. Do you think i will lose top end and perhaps gain some low end?
PostPosted: Mon Oct 24, 2011 3:26 pm
woosh wrote:
No the power wont be the same as a cr but its going to be better than the mt and he wont have to worry about the pipe getting beat to hell. I love the looks of the down pipe its what I use on my mt250 but I hate the fact that they are just hanging there in the wind. It also makes two up riding a real chore with the down pipe, my girlfriend had to use the pipe as a foot rest, lol shes affraid of the bike tho its got too much power and shes affraid shes going to fall off the back.
Woosh, I agree. I just think the downpipe is a looks killer. its too frightening to think of what is about to reach up and attack it off road and on road it just looks like a road bike with knobblies which isnt the look i wanted. But... if the pipe i have doesnt work at all with the bike then i will be forced to buy a DG i guess.
Interesting on losing the footpeg, I hadnt even considered that aspect, but of course the pipe sweeps up there.
PostPosted: Tue Oct 25, 2011 11:06 am
no, i think it is too small.
you can use it on a 250/350cc trials engine or 125cc street bike. :wink:
the cr cylinder is designed for high power at topend and it will not work adequate with a small carb and wrong pipe.
i guess a 32 carb is the minimum you need.
if your pipe doesn´t work i think a proform pipe will be better than a DG.
the proform gives your engine a wider usuable powerband than a DG.
PostPosted: Tue Oct 25, 2011 2:31 pm
b-joe wrote:
JonW wrote:
....if your pipe doesn´t work i think a proform pipe will be better than a DG.
Wish I had ponied up for the Pro-Form pipe instead of the DG. The DG is damn loud & the steel seems thin. I put a nice dent in the bottom of mine already. :oops:
WWW.CADDY500.COM
The High Performance
Big Block Cadillac Forum
PostPosted: Wed Oct 26, 2011 1:53 am
Hmm... ProForm sounds good guys.... its tempting.... I'll see how this one runs first i guess...
PostPosted: Wed Oct 26, 2011 1:56 am
rayivers wrote:
Jon,
The straight part of my Bassani's silencer section is 16" long, and it appears to 'turn the corner' for a few more inches just like yours does.
Ray, working back towards the front... my pipe has a 16.75" silencer, then another 4inches of 'bend', then the body of the 'expansion' (term used loosely) is just over 23".
I defo dont have a top clamp, just the lower one... should i weld one on?
PostPosted: Wed Oct 26, 2011 7:28 am
Jon,
I think it would be a very good idea to use a top mount, especially with a silencer this long. If you don't, you may have a lot of outward pipe motion and possibly leakage around the manifold. I'm also a big believer in redundant pipe mounting, having had to head home early a few times holding a hot pipe on with my leg. :)
My Bassani came with a simple sheet-metal strap that wrapped around the silencer and bolted to the top shock mount. It applied way too much wrapping force to the silencer for my taste, so I used a long bolt and spacers to mount the pipe for testing. If you're making up a strap from scratch, you can make it the right length to start with and shouldn't need all that.
As you know, it's important for exhaust mounts to allow for pipe expansion, which the strap mount should provide. I was going to weld up a bracket directly from my silencer to the frame, but after reading the warnings in the SuperTrapp instructions NOT to do this I used a large rubber radiator mount from a newer YZ450F I had laying around, in a tab welded to the silencer body. It holds the silencer firmly, but allows for a small amount of motion and damps vibration too.
PostPosted: Thu Oct 27, 2011 3:18 pm
Thanks Ray, youre thinking along the same lines as I am. Its a light pipe, but its a long 'lever' when it gets knocked at the far end.
My plan wouldnt be to strap it i think or even use a clamp as such, I will weld on a tab to the top and then use the standard MT rubber pipe mount bracket on the shock mount, so similar to what you suggest. Absolutely you shouldnt bolt anything directly to the frame, it should have a rubber damper in there.
PostPosted: Thu Oct 27, 2011 4:42 pm
Jon,
Funny you should mention that mount... I replaced it on my friend's MT a few days ago. Yes, that should work great. I would have done the same on my MR (the MR rear pipe mount is nearly identical to the MT250's) but the new pipe tucked in too far and I had to weld up a new frame bracket using a rubber fuel-tank grommet. Now for a new center mount, and I should be done (for now).
PostPosted: Thu Oct 27, 2011 4:49 pm
Yeah the MT had some quite good mounts for teh pipe if im honest, probably cos the OEM was a boat anchor thet seriously needed holding!
Interesting on the fitting, Ive so far assumed the fitting will be the same as the MT, as right now i dont have a small end bearing that fits so dont have my top end on, once thats done i can trial fit the pipe..... exciting times!
Do you have any photos of your install Ray? would be keen to see them :)
PostPosted: Fri Oct 28, 2011 7:51 pm
Jon,
OK, second try ...
Here's the entire exhaust on the bike:
... and here's a composite of the pipe's fit to the frame (left and top) and the various mounts (bottom right):
The mounting is pretty solid even without a center mount; there's no way the pipe can twist or droop unless something breaks. It really can't be tucked in any tighter without hitting something, either.
PostPosted: Sat Oct 29, 2011 2:31 am
Ray, superb work as ever my friend! Thanks for that. Once ive got my engine together, i will sort this and do pics for completeness. Cheers!
PostPosted: Sat Oct 29, 2011 11:44 am
Ray,
What type of tail-light/plate mount are you using? That looks nice & low. I still have the chrome tower on mine & it has to go.
~JM~
WWW.CADDY500.COM
PostPosted: Sat Oct 29, 2011 12:26 pm
JM,
It's an Acerbis Dual Sport taillight:
http://www.amazon.com/Acerbis-Dual-Spor ... B001A6PVLG
I believe it's wired for both tail and brake lights.
