It is currently Thu Jun 19, 2025 6:59 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Oct 30, 2011 12:21 pm
Cool! Thanks.
~JM~
WWW.CADDY500.COM
The High Performance
Big Block Cadillac Forum
PostPosted: Mon Oct 31, 2011 11:27 pm
Had a go at fitting this today as I finally got my small end bearing so the top end is on. I hadnt ground any of the fins on the top if the head so the pipe sticks out a little way and yet the middle (low) bracket lines up ok. the rear one i did a temp fix on, i added a jubilee clip and an old exhaust bracket that had lost its rubber after some gentle bending. this works well and will prove the pipe is either a goer or not, and if not i havent ruined it for the next guy or messed up my head...
pics to follow...
PostPosted: Tue Nov 01, 2011 4:32 pm
If i shaved the fins slightly this would fit better...
This is the extender bracket that came with the pipe, I reckon it should be maybe half a cm to 1cm longer if i shaved the head fins.
That would allow it to fit higher at the rear mount
Temp fix for the mount as mentioned above, and old bracket and a jubilee clip, surprisingly solid actually LOL
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 45 guests
