It is currently Sun Aug 17, 2025 4:45 pm
 Post subject: forks
PostPosted: Thu Sep 02, 2004 7:55 pm
I have two questions
- how much fork oil do i need for a 1979 cr250 for each fork?
- what size for seal driver do i need for the same bike.?
PostPosted: Thu Sep 02, 2004 10:56 pm
RedRocket190 answered the first one some time back.
"If you just pump the old oil out of the forks; 205 cc. If you are completely re-building them; 275 cc. Weight is SAE 5-weight."
I'm not sure about the seal driver.
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Fri Sep 03, 2004 2:08 pm
If I remember correctly the fork tubes are 39mm in diameter so get a seal driver of that diameter. But really you can just warm the fork leg with a blowtorch and then tap the seal in with a large socket of the right size. Beware the dust seal that fits above the actual oil seal is a discontinued part so if you change the seals make sure you get that part out un-damaged.
