It is currently Thu Jun 19, 2025 9:43 am
 Post subject: 74 MT250 Oil Pump
PostPosted: Tue May 08, 2012 7:33 am
The oil pump on my 74 MT250 seems to be leaking from inside the pump out of the connecting pipe where the oil line feeds into it. Any suggestions? Thanks.
 Post subject: Re: 74 MT250 Oil Pump
PostPosted: Tue May 08, 2012 12:02 pm
Check the two 'banjo' fittings and plastic oil tubes near the top left of the pump. My friend's input (top) tube was cracked just to the left of the fitting. We repaired it with JB Weld, I think it will hold up OK. If that's not it, there may be a problem inside the pump.
PostPosted: Wed May 09, 2012 6:38 am
I will check into that. Thanks a lot Ray.
PostPosted: Mon May 21, 2012 12:50 pm
Fixed the oil leak, what I thought was oil coming out of the pump was actually leaking from the the feed hose from the oil tank. Pulled the hose up to the knurls and expected to see oil come out from the intake pipe of the pump, but after watching for what seemed like an eternity, saw that it was actually leaking from the hose. Found one small scratch on the inside of the tubing causing the leak. Replaced the tubing, all is good.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 35 guests
