It is currently Thu Jun 19, 2025 12:59 pm
 Post subject: 43mm forks on a 79 CR250
PostPosted: Sat Sep 22, 2012 2:30 am
Ok after reading about them I took the plunge. Bought a 82 CR250 triple clamp and had a 79 steering stem pressed into it. Got new bearings. Bought a 1983 CR480 forks, Wheel and Brake Plate and Axle. I am waiting for some Race Tech parts, but I had to put the forks on and the wheel, only to find out that the 83 axle will not fit, oh it screws in, but only 1 or 2 threads come out for the nut to attach to.
The guy that sold me the axle and brake plate claims I have an issue with the 82 triple clamp and that is what is throwing off the fitment of the axle. If this is indeed the problem, that sucks!!
Kristi J
1979 CR250 with 43mm forks, Race Tech springs and Gold Valve emulators, Works Performance shocks
PostPosted: Sat Sep 22, 2012 10:42 am
My question is, does the axle only thread into the left fork leg, or should there be a axle nut on there also?
Kristi J
PostPosted: Sat Sep 22, 2012 9:21 pm
The left-hand fork leg is threaded and when the axle is screwed all the way in you should have maybe 1/2" of the axle sticking out. Do the axle up, then pump the forks, then tighten the axle clamp on the right-hand side.
PostPosted: Tue Oct 09, 2012 11:54 pm
Thanks for the info!
Kristi J
Users browsing this forum: Majestic-12 [Bot] and 25 guests
