It is currently Fri Aug 15, 2025 7:42 am
PostPosted: Sat Dec 22, 2012 2:47 pm
How does the "Clutch Lifter" come out of the right case? I need to remove it to send out to be replated. I removed the phillips head screw below it, but it doesn't want to come out. Do I need to remove the clutch and the "Lifter Rod" first? Will the small needle bearing stay in place if I remove the lifter?
Terry
PostPosted: Sun Dec 23, 2012 8:25 am
Figured it out by removing the lifter rod and the lifter arm pulled out easily. The needle bearing is apparently pressed in the center case.
Terry
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
