It is currently Wed Aug 13, 2025 3:18 pm
 Post subject: 2 stroke mix CR250M 73
PostPosted: Fri Jan 18, 2013 10:34 am
Can anybody tell me what mix 2 stroke mix I should be running?
The 73 manual say 20 : 1. A friend recommended 50 : 1 with modern 2 stroke oil.
Thanks in advance
Clive
PostPosted: Fri Jan 18, 2013 11:10 am
I run 32:1 in my MR and it seems fine using Hondas 2 stroke oil. 50:1 no matter what oil you use does not seem to be worth taking a chance IMO.
PostPosted: Sun Jan 20, 2013 10:28 pm
I ran spectro at 32:1
I also ran a reed, radial head and grafted a CR125 ignition to mine.
Points wise 1.8~2.0 BTDC worked fairly well.
PostPosted: Mon Jan 21, 2013 4:37 am
I ...grafted a CR125 ignition to mine.
Was that difficult to do, and did it work well? I assume a later CR250M CDI ignition wouldn't work? I've searched the Web many times but this is the first I've heard of anyone fitting a CDI ignition to an early CR250M motor.
PostPosted: Mon Jan 21, 2013 11:23 am
I was Midwest regional #1 and National # 4 on it.
All I had to do was match the taper on the rotor to that of the 250 crank, then make a base plate for the stator.
Mud races here in Ohio made me toss the points. Eventually my friend, the now late Dane Leimbach, set me up with a PVL which worked well.
I spent allot of time dialing in my 2fiddy and it worked well, just not well enough as say a mag 2fiddy or a hot penton. They didnt handle near as well as a hoosk and the down pipe just plain sucked. The foot pegs would break off, the frames and aluminum tank would break......
I ran a DG radial head, GEM reed, T&M swingarm, 125 steel tank, jemco pipe and not in the pic was works rear shock.
As soon as I could I built a mag 2fiddy......
Ill BET I still have the set up somewhere in my vast inventory.
PostPosted: Tue Jan 22, 2013 10:56 am
all my bikes get 1:50 without any problems for many years now.
PostPosted: Wed Jan 23, 2013 8:48 pm
hahaha try 50:1 on an air cooled engine at Southwick..............
PostPosted: Thu Jan 24, 2013 6:37 pm
that would be no problem.
we also have deep sand tracks here.
