It is currently Fri Aug 15, 2025 12:12 am
PostPosted: Thu Feb 21, 2013 9:37 am
I just bored over the jug on my MT250 and an installing a Wiseco piston. The instructions that came with the piston talk about drilling two holes in the piston skirt. What is the purpose of that, and do I need to do that? My original honda piston looks very much like the Wiseco piston and has no holes drilled in the skirt.
PostPosted: Thu Feb 21, 2013 11:51 am
You drill 2 small holes on the EXHAUST side of the piston, ONLY if you have a BRIDGED EXHAUST PORT.
This is to aid in oiling of the birdge so you dont lock the ring up on it. OR you can relief the bridge so there is a few thousants clearance between the ring and the bridge.
PostPosted: Thu Feb 21, 2013 6:17 pm
Thanks. That makes sense. Since there's no exhaust bridge, I won't have to worry about it.
PostPosted: Thu Feb 21, 2013 6:20 pm
You are correct, no bridge, no drill. Enjoy
PostPosted: Fri Feb 22, 2013 11:46 am
Just curious - is there any harm if you drill even though the bridge has been relieved?
osu_cowboy
PostPosted: Fri Feb 22, 2013 12:06 pm
You can, for extra insurance.
PostPosted: Sat Feb 23, 2013 11:54 am
Thanks!
osu_cowboy
Users browsing this forum: Google [Bot] and 11 guests
