It is currently Sat Aug 09, 2025 5:00 pm
PostPosted: Sat Apr 06, 2013 3:47 pm
There's a missing rear brake stopper arm on the 1974 CR125M that I work right now. Can someone tell me the lenght of this arm between the center of the 2 holes?
(part #3 in yellow on the picture)
Thanks!
1974 Honda CR125M - 1977 Honda CB750 - 1982 Yamaha XT550 - 1986 Honda TLR200 - 2016 Honda CRF1000L Africa Twin- 2012 Ossa TR280i
PostPosted: Sat Apr 06, 2013 5:37 pm
14.25" between bolt centers.
PostPosted: Sat Apr 06, 2013 5:49 pm
Thanks, I'll made one of the right size!
PostPosted: Sat Apr 06, 2013 9:22 pm
I know Im a goofball with doing crazy things to my bikes but I made an aluminum one that went straight down from the bottom shock bolt, simply because the Red-Line swingarm I ran didnt have a front brake arm mount.
I saw something similar on Marty Smiths bike at Mid Ohio in 75
PostPosted: Sun Apr 07, 2013 4:00 am
I did nearly the same thing (very similar to your 2nd photo) and it seemed like the rear wheel hopped less under braking than with the stock setup. If I go with a custom arm I'll definitely be using the shorter brake stay.
PostPosted: Sun Apr 07, 2013 5:05 am
Interesting! But to do that I will need to remove the already painted swingarm to weld an attachment for the arm and then paint it again.
Nice bike rayivers!
PostPosted: Sun Apr 07, 2013 6:49 am
I just drilled a hole in the swingarm gusset, slightly below the bottom front of the shock mount. I shortened a spare brake stay, flattened & drilled one end, bent it to fit, and that was that; used it for years with no problems at all.
PostPosted: Sun Apr 07, 2013 7:25 am
I'll see if I can do something similar on the stock swingarm.
Thanks Ray!
