It is currently Thu Jun 19, 2025 5:50 am
 Post subject: flywheel puller ?
PostPosted: Sun Apr 07, 2013 1:27 am
I did a search and did not find a definate answer. What is the correct size puller for a 1974 mt 125?
Is it a 18mm,20mm or 27mm, left or right hand thread?
I hav'nt had time to pull the cover off and would like to get one ordered. thanks
 Post subject: Re: flywheel puller ?
PostPosted: Sun Apr 07, 2013 4:25 am
I believe this one will work on the MT125 flywheel, but I've only used it on the MR175.
http://www.186mph.com/prod_16010.html
It's a K&N 82-0150, or Motion Pro 08-0026. The threads are 27mm x 1mm, left-hand.
It's hard to find definitive answers about pullers sometimes - seems like the puller might fit 20 different models, but only 10 are listed. I looked in 3 separate catalogs just now, and none mention the MT125 or the MR175, just "Honda 2-stroke MX bikes" or whatever.
If you get it thru Amazon and it doesn't work, you could probably return it without trouble.
PostPosted: Mon Apr 08, 2013 4:34 pm
I bought one ebay for a few bucks for my MT250. Worked like a charm.
PostPosted: Mon Apr 08, 2013 11:15 pm
i found a universal kit on ebay. hopefully it will have the right one in it. i'm always working on something so i should find a use for the extras.
