andy4589 wrote:
are those different from the boyesen reeds? I did think about trying a set of those. Did they make a big difference in the power? Most of the reason I was looking at changing the reed cage was so I could get a bigger carb on it without the cage turning into a bottleneck. With a decent port job and some exhaust modification it should flow enough to make the bigger carb do some good shouldn't it? That was my thought anyway. I may be way off, I haven't seen any of these modified at all until now
they are fantastic bikes to hop up and it is possible you can give mild big bore bikes,some 250's and even some competition 175 Enduros or dual purpose 175 Enduros a real hard time.
here is a video of one of my later rides on the 78 DT175,it was made in late April or early May and it was cold then so no top end runs.i let it wind out in first and second gear and did this by rolling on the throttle.i also did some roll ons later in the video to show how well it pulls.
top end i suspect would be around 70-75 MPH.the 24 mm carb and stock RT180 pipe is likely holding it back so there is still a lot of untapped potential in the engine.
i also went cow trailing and paused to take a picture of a very scenic area.
both the video in the first image and the image below it has a FMF Turbine core 2 universal 1 1/8" silencer installed.
click the first image to see the video,it can now wind to 9500 due to going a bit leaner on the jetting,mainly the main jet.
