It is currently Fri Jul 25, 2025 7:42 pm
 Post subject: Reed Valve
PostPosted: Wed Jan 01, 2014 8:25 am
Hi folks,
does anyone have one of these or know where I could get one or any info as to this item or other reed valves?
cheers people
1976 Yamaha TY80 X 2, 1977 Yamaha TY250 X 2, 1976 & 1978 Honda CR125 Elsinores, 2013 Harley Davidson 48 Special.
Range Rover Vouge Black Edition, a Little Smart four two and a shed load of other shit!!
 Post subject: Re: Reed Valve
PostPosted: Wed Jan 01, 2014 11:31 am
That looks like a G.E.M. reed valve to me, but I could be wrong. They pop up on eBay from time to time.
The setup below is way better, and probably way more $$.
http://richstaylordporting.com/intake.html
PostPosted: Thu Jan 02, 2014 8:58 am
Is this one?
PostPosted: Thu Jan 02, 2014 9:32 am
That looks like a DH reed kit.
If you're installing from scratch, I'm sure you're aware there's a lot of work involved to correctly install this kit (intake passage mods, adding piston-skirt windows, boost port cut, etc.). If you're going to go to all that trouble anyway I'd suggest using a modern reed assembly instead, but that's just my opinion.
On page 2 of the .pdf link below is a DH installation diagram for the Hodaka 125, which gives a general idea of what's required.
http://www.strictlyhodaka.com/v/vspfiles/assets/RV.pdf
PostPosted: Thu Jan 09, 2014 12:04 pm
Top oneis a GEM (that pic is of my old one actually)
the bottom is a DH.
Don't forget you WILL need to put some holes in the piston for any reed to work.
I have the diagram for a 123 somewhere if you need I will look for it.
