It is currently Wed Jun 18, 2025 10:34 pm
PostPosted: Tue Aug 12, 2014 10:36 am
The chrome plating on my 78 cr250 cylinder is starting to come off.
This cylinder has a bridged exhaust port, I thought someone in the past told me that the 79's had a bridged exhaust port and the 78's didn't, is this accurate?
Here are the engine numbers:
CR250ORE
1005432
Are there any differences between a 78 and 79 cylinder?
What are my options for repairing this, and what is you experience with it.
Thanks for any advise on this.
PostPosted: Wed Aug 13, 2014 1:06 am
Another option would be to have a new liner pressed in. Then you would have over bores available.
PostPosted: Wed Aug 13, 2014 4:59 pm
79 cylinder has a bridge in the intake port for longer piston life . Send it out and get it plated . Don't go the sleeve route as the sleeve is a huge heat sink . We do a nice 2mm overbore with porting to match if you need a little extra grunt .
PostPosted: Thu Aug 14, 2014 9:34 am
my cylinders are nicasil replated, much better than chrome plating or iron liners.
