It is currently Wed Jun 18, 2025 8:24 pm
 Post subject: Winker Relay
PostPosted: Thu Oct 23, 2014 4:39 am
Have the new blinkers and they will light up when activated but DON'T blink. Where is the winker relay located on a '76 MT250 Elsinore?
Thanks!
 Post subject: Re: Winker Relay
PostPosted: Thu Oct 23, 2014 8:42 am
The winker relay should be located under the gas tank. You should be able to see and access it without removing the tank. I have used a 12 volt relay, which works after a few second delay. I don't know where to find a 6 volt.
PostPosted: Thu Oct 23, 2014 6:11 pm
You can use an automotive 6 volt relay ,it's just bigger on the outside. You would probably have to look at a early 50's vehicle to find one . On the mt125 it is under the battery cover.
PostPosted: Thu Oct 23, 2014 11:28 pm
If you haven't done so already, take a look at the shop manual in the manuals section of http://www.honda-elsinore.com/.
On page 81 is an exploded view. Part no. 9 is the winker relay.
