It is currently Sat Aug 02, 2025 1:38 am
PostPosted: Fri Aug 07, 2015 6:57 am
Hi all, new to the forum.. so a quick introduction.
I am Rowan, from Oxfordshire in the UK.
First vintage Dirt bike that I purchased was a 1973 CR250, however it has had an engine swap to an MT250. Also just looking at purchasing a few other 60's/70's bikes with my father at the moment.. a few projects to get our teeth into.
I have a question, which was my reason for seeking out a Forum..
There is a Mikuni carb fitted to my bike, however I cannot identify it at all.. (will get the numbers from it at some point) but I have searched high and low - to no avail.
I recently took it apart to clean and in all of my wisdom, put the floats back in upside down, so when I put it back together I have bent the little float lever/tang inside.. so struggling to get it back to the right angle.
basically I am considering purchasing a new Carb for the bike - so my question is " what carb would people recommend for the MT250 engine?"
My Kick starter also doesn't spring-back and flails around.. any ideas how I can fix this (aside from the bendy bit of metal used to hold it in place at the moment :) )
PostPosted: Mon Aug 24, 2015 2:40 am
Any help appreciated :)
PostPosted: Mon Aug 24, 2015 4:26 pm
Your kick start spring is broken and the only way I know to fix it is find one on ebay .split the case and put the non broken one in. I'd find a service manual while I was at it also. take lots of pictures before also.
PostPosted: Tue Aug 25, 2015 5:53 am
On your kick starter your spring(28258-357-020) is weak or broken which in turn most likely broke your pawl(28255-357-010)
You do not have to split the cases to inspect and change just remove the clutch cover and remove the return spring and the kick shaft will pull out. But I would definitely get a manual.
Good luck
73 Honda CR250m
74 Honda CR250m
75 Honda CR250m1
76 Honda CR250m1
80 Honda CR250R
79 Yamaha YZ250F
79 Yamaha YZ400F
74 Yamaha GTMX80
75 Honda MT250 x3
66 Honda CA77 305 Dream x2
67 Honda CB77 305 Super Hawk
2009 Yamaha YZ250 2-smoker
2008 Honda CRF150RB
