It is currently Sun Aug 03, 2025 5:44 am
 Post subject: Honda mt250 carb
PostPosted: Tue Dec 06, 2016 12:48 pm
I have a 74 mt250 I cant find any info what size of 0 ring is used on the float bowl drain plug on the left side, And is there any other carb that is a replacement and will bolt up.
 Post subject: Re: Honda mt250 carb
PostPosted: Wed Dec 07, 2016 10:06 am
If you have the stock carb (with the large drain plug on the bottom of the float bowl), a Honda 91302-KE8-003 O-ring works well.
Early CR125M and all MR175 carbs are nearly identical to the OEM MT250 carb and fit perfectly. A new Keihin PE28 carb should work, but will need an adaptor for the airbox end.
