It is currently Sun Aug 17, 2025 8:28 pm
PostPosted: Tue Dec 12, 2017 5:49 pm
What is a good oil to use for the MT250's oil injection system that it currently available?
Thanks in advance :D
'75 CR250 '75 MT250 '75 DT400 '88 Husky XC430 '08 Ducati Hypermotard '09 Husky TE510
PostPosted: Tue Dec 12, 2017 6:01 pm
Bel-Ray Si-7 is an excellent 2t injector lube. Unfortunately, the MT injection system tends to significantly over-oil the engine, so you may want to adjust the oil-pump cable down a bit, run a hotter plug, etc.
PostPosted: Tue Dec 12, 2017 6:05 pm
Thanks for the quick reply. :D
PostPosted: Thu Dec 28, 2017 8:46 pm
You mentioned to "...adjust the oil-pump cable down a bit..." I'm assuming you mean to loosen the cable at the oil pump and put a little more slack in the cable, correct? Any way to quantify or all trial and error?
Back in the day I seem to remember just jumping on mine, firing it up and away I went with a strong, smooth pull through the power band. Hoping to get this one running that way too.
Thanks.
Kevin
'74 MT 250
2010 Honda Gold Wing
2009 Kawasaki Concours 1400
PostPosted: Thu Dec 28, 2017 10:11 pm
Yes. Both the bikes I worked on would surely still be over-oiled even with enough cable slack to keep the idle oil output up to @ 3,000 rpm. Pump output is dependent on both cable position and rpm.
Absolutely - disconnect the oil feed at the intake manifold and run it into a small plastic bag, plug the manifold hole, and run premix. You'll likely find the bike runs noticeably crisper, and you'll have a very good idea of pump output.
