It is currently Sat Jul 05, 2025 12:14 am
PostPosted: Sun Jan 30, 2005 6:40 pm
alright i was goin for a pit ride this summer when duhhhhhhmmmm bike dies. i lost all spark! then it suddnely starts running and keeps on dying theres new plugs in it my points look alright i dont know about my coil tjo was my bike supposed to have 2 plugs?
PostPosted: Mon Jan 31, 2005 12:13 pm
Just to make sure I would sand the points and maybe replace the condensor. I have checked what looked to be good points for closure using a DVM and found they weren't closing reliably. I've also had points go out due to a bad condensor letting them oxidize and stop making contact.
 Post subject: bike won't run
PostPosted: Mon Jan 31, 2005 1:09 pm
you don't have two spark plugs, the side one should have a plug in it and put the sparkplum in the middle for consitancey
1974/75 Honda MT 250
Rules are put there to be broken.
PostPosted: Mon Jan 31, 2005 8:43 pm
so is my biek supposed to have 2 plugs if so were the do i find a duel coil that would work?? like can i jerry rig a twin bike coil to it?
PostPosted: Thu Feb 03, 2005 6:48 pm
Some keep a spare plug in the second hole. It can also be used to install a compression release. The bike came with a spark plug fitted in the hole on the top center. The other hole was plugged with short bolt. The coil should connect only to one plug at a time. You might need a new coil. By the way, you can not remove the primary wire without breaking it.
I had my bike stop on me last summer. After checking the points, I removed the tank and found the wire connecting the coil to the points slipped out of its connection. I tighten the connection slightly with some pliers and plugged it back in. Has worked fine since. Trace your wires and connections.
Users browsing this forum: Google [Bot] and 26 guests
