It is currently Sat Jul 05, 2025 1:16 am
 Post subject: rusty tank
PostPosted: Wed Dec 22, 2004 5:02 pm
Anyone know any tricks or good products for removing the rust from the inside of a steel MR/MT tank?
PostPosted: Wed Dec 22, 2004 6:48 pm
Keith,
There are at least two old post about this subject. Use the search feature ( Spyglass under Knowledge Base ) and type in Tank Rust and then try Rusty Tank. Happy shaking! :D
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
 Post subject: rusty fuel tank
PostPosted: Mon Jan 31, 2005 8:32 am
i restore and paint bike parts and i use a product called p.o.r 15 and they make a great tank repair kit ,if this helps at all....javascript:emoticon(':D')
Very Happy
PostPosted: Mon Jan 31, 2005 10:12 am
i know i just took mine to a loacal rad shop and they blasted and recoted it. but i have used a lot of carb cleaner and bb's and shook it if it wasnt that bad before.
 Post subject: rust-away
PostPosted: Mon Jan 31, 2005 6:26 pm
the best rust removal i've found yet is Distilled White Vinigar. You can get a gallon for under 2 bucks at the grocery store. Just pour it in the tank and let it sit a couple days. then just get a bottle cleaner and brush the stuff away. it comes off like nothing after soaking in the vinigar. this also works really well with bolts, just remember to spray down with WD-40 after you remove the rust, or else it'll return.
keith
PostPosted: Wed Feb 02, 2005 12:43 pm
I used to use gravel or nuts and bolts but switched over to ~3-6 feet of chain. Seems to rattle around better and I never get an odd chunk of rock or nut left behind when I pull it out.
PostPosted: Fri Feb 04, 2005 10:46 pm
Good idea on the chain. (not a motorcycle chain). I will do that the next time over gravel...
